Todd Menswar
Thread starter- Joined
- Aug 1, 2015
- 15
Does the choke plate in the carb need to sit flat against the chamber? Or does it lean, leaving a small gap (1/8 - 1/4 in.) at bottom of chamber? Would that have anything to do with my cylinders misfiring/sputtering? The compression in the cylinders is ok 110/118. I am getting spark jumping the gap. If it idles at very low speed, it will eventually die out, but I can get it to idle at lower speed while misfiring. Someone mentioned reed valves. Where would they be located? I have a 1987 25 hp Johnson. Thank you.
