Remove Powerhead 1989 28hp SPL e28eslcea
Squawsher
I recently picked up a motor with some corrosion and other paint issues mostly on the lower engine cover. Therefore, I am in the process of removing the powerhead so that I can then remove the lower engine cover for sandblasting and paint.
I have removed the four bolts facing up from exhaust housing in the rear half of the motor and the two nuts from the studs in the front half of motor, as well as disconnected the shift linkage, but the powerhead still won't budge.
Is there something else I need to remove to get the powerhead separated from the lower engine cover and exhaust housing (there appears to be a nut/bolt way up inside the exhaust housing when viewed from below where the midsection would attach, not sure if it needs to come out?)
Any help from those with knowledge/experience in this area would be greatly appreciated as I am out of ideas and don't want to break anything.
TIA
Squawsher
Still stuck.
In hopes that it would help break the bind, I removed the four bolts that hold the lower engine cover on and it is now free floating but the powerhead still won't let go.
Anyone out there?
jbcurt00
Most of the motor gurus work or have worked in the industry. And it's boating season, lots of topics getting posted needing lots of help.
It's only been 2 hrs between your posts.
Give them a bit.
If you want to bring your topic back to the top of the Johnson forum just post a
Bump
or
BTTT
Post to bring your topic back to the top of the list of topics.
Check your PMs
Squawsher
Thanks for the heads up. Just didn't want my post to get buried in the topic/thread lists as I am sure they grow rapidly this time of year.
jbcurt00
Yep ^^^
Hence the BTTT or bump suggestion.
Got both your PMs and replied. I forwarded your request. Thanks John
sutor623
Not sure about the nut that you speak of. I do know that because of heat and corrosion those powerhead gaskets will stick to the midsection pretty good. I have had to use a rubber mallet in the past to smack the powerhead loose. It may also help to completely remove the lower unit instead of just disconnecting the shift linkage. That driveshaft is just another sticking point. I ALWAYS remove the lower unit when doing a powerhead job.
Squawsher
Thanks. I may have mispoke.. i dropped the lower unit and extention clean off. I have not taken out the shift lever itself.. Does it need to come out as well? It doesn't look to be attached to any part of the powerhead but to the outer exhaust housing.
Where is the best place to beat on the powerhead and knock her loose?
Can anyone confirm that there are only 6 bolts/nuts holding it on?
Thanks again.
Squawsher
No Title
Here is a pic of the 4 bolts removed from midsection facing up.
Squawsher
No Title
And a pic of each nut removed from post from inside lower engine cover on front portion of powerhead.
sutor623
Make sure to confirm that there are only 6 bolts first because I am just not sure, but I normally smack lightly all around the powerhead wherever there is bare metal to get to. The higher up you smack, the better the leverage.
Squawsher
I shouldnt have to remove the flywheel should I?
Sorry if these are amature questions, just want to make sure I'm doing everything right.
Anyone have an 89 evinrude book they could glance at for the proper procedure b4 I start whackin it?
This starting to read like a comic strip.---No you don''t have to remove the flywheel !!!--And 4 bolts and 2 nuts are to be removed.--Next step is to try and remove the lower unit to confirm that driveshaft is not seized into the crankshaft.---Take this one wee step at a time.---And you are sure of the condition of this motor and lower unit ?---Be a shame to splash paint on a motor that is not in good condition.
Squawsher
Thanks for the reply.
Motor starts, runs, and shifts good.. only problem Ive noticed thus far is that it pumped water but not to the motor (so I barely ran it).
Took the lower unit off to inspect water pump and all looked good. Either the guy had it apart and didn't get water tube realigned properly or there is a Crack in the tube somewhere within the midsection (my second reason for wanting to get the powerhead off is to thoroughly inspect the tube).
So no go on the flywheel. Good.
What about the shift lever itself? Looks to be attached to the midsection and not to the lower engine cover or powerhead?
Thanks again.
Yes you have to disconnect some shift pieces on the side of the block.---Gently pry up under a corner of the cylinder head.-----Sometimes the gasket gets a good hold on it.
Squawsher
No Title
Thanks. Here is a picture of the shift lever outside and inside the lower engine cover as it currently sits. Not sure what all needs to come off as far as the shift lever goes, hard to see from the pictures, but doesn't look like there is anything attached to the block. Take it all off? ;)
The stuff that needs to be disconnected is " missing " and so there is now nothing to disconnect there !!-----Post # 12 talks about painting a motor that is not in good condition.------------Post a picture of the side of the block.------You might want to investigate why these bits are missing.-----Have you done a compression test ?
Squawsher
No Title
Tested by hand, yes. With a guage, no.
Also, the motor was started and ran for about 20 seconds until I noticed it was not **** in and shut it off. Purred like a kitten and seemed to shift just fine. Didn't know it was missing something though.
Have yet to start really beating on it as I wanted to be sure everything else is outta the way.
Here is a pic of that side of the block.
The shift interlock pieces appear to be missing.---Experience tell me that someone was having issues with the running of this motor.--Removed this stuff and sold the motor ???--Check this motor out before you worry about painting / making it look pretty.
Squawsher
What else should I check out? Like I said, good spark, good compression, ran good, shifted good, or so I thought. Didn't think I was buying a peach but don't think it's a brick either. What else should I check before proceeding?
Thanks.
Squawsher
Do you know where in the schematics / parts diagrams for my motor the "shift interlock" is located?
I can't seem to find the missing part(s) in any of the diagrams of the motors different sections.
Thanks again for all the help.
