I recently picked up a motor with some corrosion and other paint issues mostly on the lower engine cover. Therefore, I am in the process of removing the powerhead so that I can then remove the lower engine cover for sandblasting and paint.
I have removed the four bolts facing up from exhaust housing in the rear half of the motor and the two nuts from the studs in the front half of motor, as well as disconnected the shift linkage, but the powerhead still won't budge.
Is there something else I need to remove to get the powerhead separated from the lower engine cover and exhaust housing (there appears to be a nut/bolt way up inside the exhaust housing when viewed from below where the midsection would attach, not sure if it needs to come out?)
Any help from those with knowledge/experience in this area would be greatly appreciated as I am out of ideas and don't want to break anything.
TIA
TIA
