- Jul 18, 2011
- 19,602
My port engine is showing signs of a cooling system issue, so it looks like I have to do some maintenance while the boat is in the water, as pulling the boat and re-launching it is wicked expensive.
Some Info & Symptoms so far are:
Twin engines per my sig below . . . FULL closed cooling systems with sea water strainers before the sea water pumps.
1) When I come off plane and go to 'no wake' speed both engines rise in temp as expected, and then return to normal temp ranges. . . . lately, the port engine is rising higher and staying at elevated temp for several minutes, while the starboard engine returns to normal temp within a minute.
2) Cruising speeds - both engines run at their normal temp range (160-165)
3) Higher speeds - the port engine starts creeping up in temp to 170-175 while the starboard engine stays at 165.
4) Staying at idle speeds for a while, both engines go down to 150-155.
So, I am thinking that either the sea water strainer has become partially clogged with marine growth . . . or I may have an impeller failure in the making . . . and if so, it may have some impeller fragments partially blocking the water flow at the oil cooler.
I inspected both engine impellers during pre-season prep and they looked good . . . about 100 hours total on the impellers. Normally, I would replace them going into next season (150 hours)
This will be the first time I have done cooling system work while the boat is in the water, which may be 'very exciting' once I disconnect the hose to the sea water pump. The best that I can tell is that the intake hose is slightly below the water line, so water will probably come rushing in. I think I can raise the hose or plug it up while I do the work. We shall see. . . . :noidea:
T.I.A. for any words of experience or advice on this :thumb:
