further
Thread starter- Joined
- Jun 18, 2009
- 1,038
Hey guys, so this is my second season (well officially first full season) with this boat and motor/outdrive - 215 hours. First splash this season, I noticed a pretty heavy sheen/oil slick in the water at the dock right after i put in. I replaced all fluids at the end of the season last year and made sure all was tight (bellows are all new and tight). I attributed the oil sheen to the fogging oil i used to winterize as well as the coating of T-9 i put on the outdrive prior to winter. Ran fine, no issues with operation at all. Second time out, last weekend didn't notice any oil sheen on the water at all so all good. Yesterday, was out on the water and again noticed a sheen while anchored in a cove, but the sheen didn't really look like oil which is normally rainbowish, this was mostly whitish. I did just re-wax the hull with marine 31 spray wax so maybe that was it? I also checked the outdrive oil before putting in yesterday and all levels and clarity are good. All operation is excellent and no issues with going into forward/neutral/reverse and no signs of leaking anything at the outdrive when I took the boat out of the water at the end of the day yesterday.
Bilge is completely dry after 3 hours in the water cruising and anchored, nothing leaking.
So do you think this sheen could be the wax? Am I being paranoid?
Another question which may be silly but I'm a newbie at this so what O-rings do you all use at the outdrive fill, drain and dipstick locations? Does it matter?
Thanks as always...
Thanks as always...
