findinghomer
- Nov 7, 2009
- 342
Hi guys. 1997 5.7 alpha 1 gen 2. Had no issues, but decided to change my bellows, seals and shift cable. "While I was in there" also changed my gimbal bearing . now with job complete, and brand new bearing, I get I knocking/clicking when I cut the wheel sharp left our right. Happens in forward , reverse, or even just sitting there idling, all trim positions. Sounds normall under normal operating conditions. I find it hard to believe my u joints coincidentally are bad , right after doing this service . I did have an issue where I didn't think I had my bearing was all the way in. Turns out I did , so I was frivolously pounding on the driving tool more times then needed. Do you think I screwed up the new bearing by pounding on it when it was all the way in already? Or is it my u joint? Ooh, and yes I used an alignment check tool when reinstalling the drive. I would rather not mess with the u joints unless I have too. Hopefully someone has some input. Thanks!
