64osby
Thread starter- Joined
- Jul 28, 2009
- 6,826
Spent a little more time on a project trailer today. It is an 18' frame dual axle trailer. When I picked it up it was in pieces and scattered about the PO's side yard. I have assembled the frame and axles, found some 5.7 x 8" tires and put those on (same size as the two that came with it).
Two of the hubs had way to much play and can't be tightened up. Pretty sure it is time for some new bearing kits, possibly new hubs.
Spent way too much time looking on etrailer. The only numbers that I can find are the outer bearing LM6 7048 and the bearing buddy is a 2328. The hub / wheels are 5 / 4.5. Pretty sure it is a 1" spline.
I found a bearing kit that I'm pretty sure might work. http://www.etrailer.com/p-BK3-310.html
I am considering new hub maybe a set with brakes. This is where I get confused.
On etrailer the only hubs with LM67048 outer bearing are 6 lug.
Anyone out there able to help me figure this out?
