MikeDobbs
- May 8, 2015
- 206
Engine Serial # 0K277779
I'm having some difficulty getting the valves adjusted properly and have read two different suggestions for the correct method. I cannot find the correct manual for this engine- so if anyone has the link I'd very much appreciate it. Otherwise, if anyone has the manual I'd love to know how I am supposed to do this.
Method 1: You simply bring each cylinder to TDC compression stroke and torque the nuts to 20lbft of torque. This sets the last automatically.
Method 2: You bring cyl 1 to TDC compression and adjust certain valves by loosing nut until you can spin the rod between your fingers. Then, slowly tighten until you cannot spin the rod anymore. This is zero lash, and from here you tighten 3/4 of a turn.
I tried method 2 (being the first one I came across) and it seemed to go fine, but I had a fair amount of what sounded like valve train noise. So I tried it again, and now I can't even start the engine. Then I came across the second (err. 1st?) method and it sounds a lot simpler, so I'd like to give that a try tomorrow if it is correct.
Thanks in advance for any help- this has been a particularly frustrating day of working on the engine...
Video attached if you care to have a listen and suggest what you think the problem might be- or what I should do to diagnose.
