chopperguy
Thread starter- Joined
- Jun 18, 2011
- 66
Hey Guys I need some ignition help. I've had a few issues with this outboard losing spark on all cylinders on a few occassions. Got towed home and then it started right up. I began troubleshooting the ignition system based on several online references. DVA readings showed 295 volts both legs of stator to Power pack. Stator to Rectifier/regulator showed 15 and 9 volts. Tach was cutting on and off ocassionally. Based on this I changed out the Rect/reg. After change out stator to Rect/reg reads 25v and 15v and tach is stable.
My question is I read that those two leads should read within 1.5 volts of each other. With the brand new regulator each lead is still 10 volts apart and the difference is not coming from the stator. So do i still have a problem.
