Looking for a Manual. Not Seloc.
chadpcb
I have a 1992 Mercruiser Inboard. S/N is 0D624015 it is a non high performance engine. According to mercruiser website and parts catalog it is service manual #15 p/n 816463. I have tried to find this as it is particular to my engine. i do not mind paying for one as long as it doesn't cost 2 fuel tanks and a bilge pump. Prefer to a friend loan me one if possible.
Thanks,
alldodge
Thanks,
Only place I found it at no cost is boatinfo. Appears you have a ski boat. For the most part manual 17 will be able to provide you with most everything you may need unless there are some things outside of the norm
chadpcb
Not a ski boat but and offshore boat. It is a direct drive Mako 236 1982 model. Motor has been in it since I purchased it and the only thing I have had to do is rebuild the bottom end. Thanks to my buddy at the mercury dealership it only cost $260 to rebuild bottom end...
alldodge
What kind of info are you trying to get from manual 15
chadpcb
i believe I have found a link and manual.
chadpcb
a couple of things.
I just recently rebuilt my carb and I have different opinions on how to properly set it up.
Ex: IA screws 1 to 1 1/2 turns out, 3 to 5 turns out
Things of that nature.
Bt Doctur
from gently seated to 5 turns, start at 1 1/2 . if it dosent idle ,open it to 3 1/2, etc. You want the smoothest idle . turn it out till it runs rough, turn it in until it runs rough
split the difference in the rich side.spark plugs are cheaper than pistons
chadpcb
Thank you everyone for the replies and help. I now have an electronic copy of the actual service manuals on CD thanks to my buddy at mercury dealer....
chadpcb
Bt Doctur should I put the boat in the water to do the final adjustment
