trailer failed- help
brad3
I just got done replacing my wheel bearings and races on one hub. Now the nut goes all the in when tight and the hub still has play. What could be wrong? I could not find any answers.
brad3
I changed only the bearings on the other side and its fine.
smokeonthewater
Pull both sides apart and compare... Figure out what's different and you'll find the problem.
dockwrecker
Thicker outer thrust washer. Apparently your replacement inner or outer bearings are slightly smaller than OE. shouldn't be a big deal if the bearings fit the spindles properly.
MTboatguy
Are you sure you matched the new parts up with the old parts you removed? Or did you just go to the parts store, tell them what you had and they gave you what they thought was the right parts. When doing trailers, it is always best to take the old parts with you when you pick new stuff up, so you can match as close as possible. Did the old bearing fail while you were towing it? I agree with Dockwrecker, you are going to probably have to add a thicker thrust washer.
bruceb58
+1
If you used the exact same part number bearings, it should be exactly the same. You need to double check your part numbers.
Silvertip
The only way that can happen is if you forgot to install something, or the replacement bearing had a smaller outside diameter and it pulled inside the hub when you installed the nut. You did remember to install both races??
gm280
Sounds like either wrong bearings and races or somebody forgot to install a race before assembling them again...
brad3
I did install both races. I will double check the Part numbers and get back to you.
bruceb58
Are you saying you didn't replace the races on the other side?
brad3
Bruce- i only installed new races on the HUB i am having the issue with. On the other side i only installed new bearings into the old races and the hub fits fine.
brad3
I am pretty sure the new bearings were the correct size as i matched the outer bearing part# with the new bearings.
bruceb58
When you change bearings, you always change races.
bruceb58
How about the inner bearing number? Did you pop the races and make sure you bought the correct race number?
gm280
I totally agree with Bruce on this. You always change bearings AND races when you make a change. The bearing is designed to work with the proper race that comes with the bearing set. So I would change both inter and outer bearings and races as a normal change procedure. If your old race had any wear, it will wear the new bearing really quickly... JMHO!
brad3
I did not check the race numbers. I assumed because the races came with the bearings that i did not need to check the races # with the old races. I will do this and let you know what i find. I will also complete the other side in changing the races.
