sumocomputers
Thread starter- Joined
- Feb 23, 2015
- 123
First, I don't know if the two problems of hard starting and rough idle are related. And sorry for the long post, just wanted to make sure I provide as much info as possible.
When first starting with muffs or just at the dock, the engine usually starts fairly easily, after now understanding from the Secret Files the correct procedure with pushing the key in for a few seconds as well as lifting the high idle lever a bit if needed. The cranking itself seems healthy. We put Stabil Marine in every tank, and have a 6.5 gallon portable gas tank. We also have been running SeaFoam in the gas for about 5 tanks, with no real change.
The problem is that after we are in the water running for awhile, turn the engine off to fish, and then try to restart after sitting for 15-20 minutes or more, it is hard to start, and requires lifting the fast idle lever for about 30 seconds, otherwise it will die when taking off. But, if we restart in less time than that (say 5 or 10 minutes), it starts first or second time, no need for fast idle, we can just go. In all scenarios, the engine runs rough at idle, but runs well at anything above that.
We have good compression on all 3 cylinders (all 120-125), spark plugs & wires are less than 6 months old and properly gapped at .03", and don't look oily or burned.
Fuel filter was replaced recently and new snap clamps were used for everything.
Engine temps are now normal after replacing the thermostat recently. It never goes above about 160F. I have a new temp gauge, and have checked it repeatedly with an IR gun at various places on the block while in the water.
I have removed the primer solenoid, and performed both the electrical and fuel tests according the service manual, and it checks out perfect. It is in the correct position of being parallel with the primer body.
I have checked voltage at the battery. It is 12.6V at rest, and 11.6V when cranking.
I removed the fuel/bulb line completely, cut off both ends, checked for suction, and the bulb check valve seems OK. Reconnected with new hose clamps, and made sure it was in the right direction. Bulb does get somewhat firm after pumping, but not totally hard. Every time we go out in the morning, it does get soft again. Read a few things about this, and I am still not sure how it this should behave.
I have checked spark, and couldn't get any of the 3 to show a spark at 7/16", had to reduce it to 3/8", and they all had spark. The spark was very thin, not sure if that is the type of tester I have, or if that means the spark is weak. And not sure if I really need 7/16" or not.
One last thing. We notice a very little bit of green/blue spray at the bottom of the motor case (under the carbs), so I am thinking we have a very small leak somewhere around the carbs. Our gas is greenish-blue because of the Stabil-Marine and Premix Oil. If there is a leak, I suppose extra air could be getting sucked in at the leak point.
I have been reading around as well as looking at the service manual, and I have a list of things I want to try, going from cheap/easy to expensive/harder, and just wanted to see if I am on the right track.
FREE
Increase the idle speed a little with the adjustment screw? No idea if this is needed.
Check Primer lines for blockages
Check Fuel lines from pump to carb for blockage/leakage (the one with all the little Ts and zip ties)
Clean Carb in place (are there high and low jets?). Going to follow the Secret Files.
Check Timing. The manual makes this sound very complicated, and I don't have a timing light.
$10
Replace Airbox to Carb gasket (already have a new gasket)
$15
Replace Spark Plugs for good measure
$60
Rebuild Carbs (never done this before, looks kinda scary). Also I need to check if there are any OMC service bulletins on replacing the jets; I read this somewhere, but can't find it now.
$60
Replace Fuel/Bulb Assembly with OMC branded (the current one is a Walmart special)
$120-$360
Replace Power Pack(s). I have no idea if this is even relevant here, but have seen a few references to this, and if I need 3 of them, that is damn expensive.
Thanks,
Chris
FREE
$10
$15
$60
$60
$120-$360
Thanks,
Chris
