currentaddiction
Thread starter- Joined
- Mar 18, 2015
- 16
ok, 1st post here hoping to get some advice. To start off i overheated my engine and damaged a couple of the cylinders. had all 6 bored .20 over and installed Wiesco pistons. Changed all the bearings, checked and double checked all measurments. It turned out really great. Installed all the electronics double checking the wiring and pretty sure its all correct. it seems im getting spark, i checked it with a screwdriver going to ground and all had spark. It seems im getting fuel cause the electric pump i working and also the low pressure pump seems to work also. I did try spraying starter fluid but didnt make a difference.I'm not sure about the timing though, but i didn't change any of that. I tried using a timing light but wasnt able to see any of the marks on the flywheel. Not sure if the old timing light was too dim or if it's that far out it didn't even show up. I havent checked the switch boxes or ignition boxes either. They were working before it overheated so I'm assuming they are good. I guess it would be wise to check um out... Does it look like i'm overlooking anything??
