Looking to purchase a seadoo speedster 150 or ???
Ziggy4
I'm interested in purchasing a boat and need a little help deciding what to get. I like speed boats the most but just can't afford to buy or fuel one unless it's a mini. I also need a small boat for storage purposes. I plan on just joy riding and exploring around. I live on the Indian river in jensen beach, fl which is the intercostal, that's where I plan on using it the most. I've looked at several boats and so far I think the seadoo speedster 150 single engine is the way to go. I also looked at bowriders and boston whalers. What do you guys think of jet boats of these type's? I've heard bad things about jet boats but don't know whats true and what isn't?.
Any info is appreciated..
Jet boats are more inefficient than prop-driven boats. Up to 40% less efficient. You might integrate that with your cost projections. Get a 16-18 foot bass or speedboat with a 115HP or so outboard. It will be much more efficient, more roomy and likely much faster.
Ayuh,.... 'n while Jet power is great in shallow areas, Weeds will stop 'em Dead in seconds,.....
With a Jet, when it loads up with weeds, ya gotta shut it off, swim under the boat, 'n physically remove the weeds,...
With a prop boat, ya just go to neutral, bump reverse, gas it, then back to neutral, 'n on to forward again,......
smokeonthewater
yup if you can't afford fuel for a fast boat you REALLY can't afford fuel n 2 stroke oil for that seadoo.... THIRSTY beasts they are!
thumpar
While I am not an outboard fan I would still pick an outboard boat over a jet. They guzzle fuel. Their load capacity is usually pretty low too. My first (of my own) boat was a 16.5' with mercruiser drive. It wasn't the fastest thing in the world but it would easily pull tubes and wakeboards. You might try renting a few different ones to see what you like. The best advice I can give is to try to get in the boat world cheap with a well maintained older boat. I had my first one for 7 years and sold it for $100 more than I bought it for.
Ziggy4
Thanks for the input. The speedster looks like so much fun, it's hard to go with something else. I've always wanted a jet ski but always thought they were over priced. The jet boat looks like the same fun but more comfortable for me and the girlfriend to run around. I found this post for a boat with an outboard. Let me know what you guys think.
Up for sale no trades. 1973 wriedt 16 foot spoiler speed boat with a mercury 150 optimax. Motor is a 2010 2 stroke purchased new in 02/2010. . Has just under 300 hours on motor . Trailer is a ezloader purchased new in 2012. Boat was redone in 2009 at which time a new floor and transom were done along with a custom interior. The boat has a 24 gallon fuel tank up front. The rear has two built in coolers that drain to the rear and can hold 18 cans plus ice in each. Has. 2 1/2 gallon oil tank and dual batteries
Boat had always used ethanol free gas and premium plus quick silver plus two stroke oil. Does not have stereo
Looking at 11500 OBO.
Boat will run low mid 65 with the set up. Has a stainless steel 21 inch prop and a hydraulic jack plate
With a better prop and a good operator boat will run at least 70 mph.
Ziggy4
No didn't buy this one. Just found it on craigslist and thought it looked pretty cool. I think it's over priced though.
Slip Away
Make sure you bring ear muffs ( for loud engine) and a respirator for the stinkin' fumes each time you go out in the Speedster.
Brian 26
What year speedster?
You mentioned gas money. The older ones (mid to late 90s) are two stroke carb, LOTS OF GAS and maintenance, the newer ones are 4 stroke fuel injected and much better on gas and maintenance.
The 15' jet boats are basically a big jet ski, not something you're going to load up with friends and wake board all day on, but if it's just you and your girl it will probably work well.
Ziggy4
I'm interested in a 2006 and up, the single engine 4 stroke one. I've been on a jet ski a couple of times and loved it. This sounds perfect since I want something I can ride 2 or 3 people and island hope. I want to go fast and mess around like I did on the jet ski.
Brian 26
Just plan on it being in the shop for repairs 1 out of every 5 uses.
Can you elaborate on that?
The old seadoos were problematic (I have two of these in my garage) and require a lot of maintenance and post ride care and the twin engine boat version were double trouble, however the new fuel injected 4 stroke versions are very different. The engine and jet pump the OP is asking about is the same one used by most jet ski rental fleets as well as the guy who recently broke the world record for most miles ridden in a 24 hour period. They routinely go 1000s of hours with out major repair.
Slip Away
Elaborate = 2 stroke versions.
4 strokes= 50 to 60 hours, then into the shop:)
smclear
A little background first. I am 54 years old and have been boating since before I was born. I am the third generation to live in our lakehouse. I was born in October and my mom was out boating the entire summer before I was born. From 27 - 38, I lived in Fort Lauderdale and did a tremendous amount of boating there. I got my Captains license and while I was never Captain, I did serve as crew on many boats, the largest being a 100' Burger. In my life I have owned outboards, I/O's and straight inboards (as well as a sunfish sailboat).
With that being said, I can only speak to my own experience. In 2007, I bought (new) a speedster 150 SCIC. It is hands down the most fun boat I have ever owned. I can't speak to the normally aspirated model, but mine will easily do mid 60's in the spring and fall. The intercooler loves the colder water. And, it will reach those speeds very quickly. In the heat of the summer, it will top out at around 60. These are true speeds as measured by GPS, not the dream-o-meter. It will drink a lot of fuel but I can pretty easily get a full weekend on one tank of gas unless my crazy niece is at the lake. If she's there, It'll go through a tank per day but she does run it hard, and all day long to. Still, it's better than my Century which will go through 12 gallons per hour (it's a 440). That one really hits the wallet hard.
As to reliability, I have never had it in the shop for any reason (other than winterizing). That's 8 years of hard use with no problems. I consider it to be a great boat mechanically. I can't say if this is normal or not but I suspect it is. At least for the 4 stroke models. Sea Doo did have issues with ceramic clutch washers in their superchargers prior to 2008 but that really only affected the skis and not the boats. In 2008 they switched to steel washers and resolved that problem. If you want more info about that go to Greenhulk.net (a jet ski forum).
As to weeds, I only experienced issues one year out of the 8 I have owned it and that was only due to the fact that the lake I'm on was very low and the weeds were very close to the surface. That year, the pump did clog frequently. When it clogged, I was always able to get back to the dock. As mentioned, clearing the pump, although not hard, is a pain in the rear end. If you boat in an area where the weeds are close to the surface, that will be an issue to consider.
You often hear about steering issues with jets. The modern jet boats do not have the issues the older ones do. While there is a LARGE learning curve, once you have it down you'll discover they will out handle any other boat at ANY speed. I can spin mine 360 degrees in it's own length and move it sideways as well all at idle.
These are wet boats and if you're boating in any water with 2 -3 footers, you will take water over the bow. No worries on a smaller lake (less than 4000 acres) where 3 footers are not common. I don't know, but I'd be concerned on the intracoastal where they're much more common. At least they are in the Lauderdale area.
If I were you, I'd go with an outboard. Much more practical in your area.
Still, if you were looking for a second boat, you can't beat a little jet for the fun factor. And get the supercharged one, you won't regret it.
Sorry this post is so long. And remember, it's jusy my two cents.
keith2k455
Smclear....fantastic summary. I've always wanted more real world accounts of jet boats. I think your description of a "wet" boat is very helpful in determining if a jet boat is the right boat for someone.
Brian 26
In regards to the fun factor - I've never driven a new style one that is in question here but I have driven a 97 twin engine (85 hp each) and I would compare it to an amusement park ride (roller coaster minus the hills maybe) that you are in control of, a lot of fun to drive.
