Shallowhunter, I went through this last week. These guys guided me through w/o damage. Using lever bars through the puller to hold the crank can go wrong. There is a "vise grip" with an adjustable chain that looks like a heavy bike chain, cheap in discount tool stores. I used that to wrap / hold the flywheel WITH a length of old serpintine auto fan belt wrapped between the flywheel & chain. Worked well, No damage. To give you an idea how much force the wheel, puller & crank withstood. I used a torque wrench to tighten the puller just to see how much it would take or break. The flywheel popped free a bit over 90 lbs.. No hammer no heat and no damage. Word of caution, if the 3 GRADE 8 bolts on the puller protrude much below the bottom of the flywheel they will damage ignition components.
