shallowhunter
Thread starter- Joined
- Feb 3, 2015
- 8
Hello all,
I am a newcomer and will try to include everything. I have been trying to pull a flywheel without success. I have been trying to pull with a harmonic puller. I first tried to tighten and whack and tighten and whack. Then I tried using heat and cold to shock. I tried in combination at least once. I have also tried to use PB blaster and left for days under tension.
I have since noticed I don't have loos linkage and now considering not pulling the flywheel. I am concerned after reading about problems with a taper getting lubricant causing problems. I am not sure if it has. Should I pull the flywheel and inspect this or am I overthinking this? Also the flywheel did rise a little less than 1/8 of an inch. Any constructive input is appreciated. Thanks in advance!
1994 Johnson 30HP
VJELETA
1994 Johnson 30HP
VJELETA
