I need help to indentify this gearcase please
SparkieBoat
I purchased this gearcase off of ebay. It was listed as for a 150. It does not fit my 150. I have included some pictures. The shaft hub is about 4'. Th over all length of the part that mates to the midsection is about 20 1/4". shaft from mating part of gearcase to top is 22 3/8. I can measure anything else you need. Thanks.
Faztbullet
That looks like a late model(80-86) inline unit and only way it will fit is to remove a stud or 2.....
Dukedog
yep....in-line driveshaft splines won't "fully" engage either...
JAN.....All 2.0, 2.4, 2.5 V6 gear cases from '76 up will interchange....
Faztbullet
What up Dog????Is it cold down there?? Yep forgot about that but we used to remove stud and grind out preload pin on them old 1135 unit(1:78) to race with before the Xr cases came along...
Dukedog
just relaxin' with my coffee cup! yeah, it is. even here in Fl.
yeah, we use ta run tha coned in-line but motor and gear case were cut down ta 15's so no "engagement" problems. just tore up gears!!!
SparkieBoat
I ground off the preload pin and removed the front stud. everything lines up but the gear shifter. any idea how to mate that part up? And thanks a lot for the replies.
Dukedog
that won't work.... that pin is what keeps tha top drive shaft bearing in place...pressure on tha bearing comes from tha top of tha drive shaft seating in tha crank.....then also its to short (drive shaft) to engage completely in tha crank. ..it will end up stripping tha crank splines...........
when I was sayin' we used 'em tha drive shaft was cut and shortened "below" tha pre-load pin and spring. those have gotta stay intact...
SparkieBoat
Ok thanks. So Fazt. said that it is a 80-86 inline gearcase. can you tell me what HP motors it fits? So I can advertise it for sale. Thanks a lot
Dukedog
that's something for Faz....he's way ahead of me on in-line junk!..............
