1986 120hp johnson
jeffreymhunt
Hello;
I purchased 1986 120hp johnson, with vro removed ,with electric fuel pump wired in.
Do you know if there is a way to wire the fuel pump, to energize only if the engine is running.
Currently the pump run with key in run position.
Thanks;
Jeff
boobie
If it was my motor I'd get rid of it as it is now a fire hazard the way it is.
Outboard fuel pumps operated by crankcase pressure pulses are very simple and very reliable.----No idea why folks want to install electric pumps !
