Trim Tabs
Brad S
Have a 19' Marlin Fisherman's Cuddy. Thinking about installing trim tabs. Any suggestions as to what trim tabs to use?
Ayuh,.... Depends on just What yer expectations are,..?? or the Problems yer lookin' to fix,..??
Watermann
Nauticus Smart tabs, the factory blemish ones sold here at iboats are a great deal under 100 bones. Yous would most likely need the 80# model.
jayhanig
Master Chief Petty Officer
People are naturally going to recommend whatever kind they have. I will be the first to state that the only ones I've ever used were Nauticus Smart Tabs. I love them and have no regrets with their purchase. I come up on plane much quicker and bow wander at slow speed is a thing of the past.
That being said, people here also like Bennett tabs. If you get them, you'll have individual manual control of both of them to adapt for unusual loading. My Smart Tabs do it automatically via spring pressure but I can't manually set them if that isn't enough. So far that hasn't been an issue.
UncleWillie
+1
Why do you want them?
How big is the budget?
How much effort are you willing to expend in installing them?
MRS
I have a 19ft. with i/o on it heavy and run the Bennett SLT 10,s on it they are self ajusting and the best thing yet that I have added to the boat. Bow use to come up high had to stand to see over the bow not now and holeshot is nice, plus pulling tubes is way better to. Bennetts use springs not gas so I went with them worked for me.
Tabman
iboats.com Partner
I had not heard of a 19' Marlin Fisherman's Cuddy before so I Goggled it, cool boat! It's an inboard/outboard correct?
It looks like a "big" 19 footer. It appears to have a pretty sharp forefoot, so being able to hold the bow down at lower speeds will really smooth out the ride in a chop.
As the others have mentioned, it depends on what you want to achieve. Self leveling Trim Tabs such as Bennett SLTs or Smart Tabs will let you plane a bit slower and keep the bow down during takeoff. Get the larger ones recommended, The Bennett 10" x 10" SLT10 for instance.
Remotely controlled Trim Tabs will give you much more control over a broader range of speed, sea conditions and weight distribution, but as mentioned they are more expensive and take more time to install.
If you keep the boat in the water we recommend hydraulic Trim Tabs such as the Bennett 10" x 12" M120 system. This is what I would install if it were my boat, even if it was kept out of the water. It's a great system and takes up very little room on the transom, and fits under most swim platforms.
If the boat is dry stored you can consider an electric system such as Bennett's Bolt 12" x 12". It does take up a little more room on the transom, but takes a bit less effort to install.
I hope this helps.
I hope this helps.
Ayuh,... Hi Tom, how ya been, A-Ok I hope,....
Bennett's has really expanded their product line I see in yer post,.... Spring tabs,... electrics,.... Cool, Lotsa choices,....
My over-sized helm controlled hyd. Bennetts are still workin' just Fine,... been on that fishin' barge, goin' on 16 trouble free years,.... ;)
Tabman
iboats.com Partner
Hi Bondo!
I am very well, thanks for asking. I hope the same goes for you too!
Glad to hear your Tabs are still working well, 16 years is not that old for a Bennett system :)
Yes we have really expanded our products! Don't forget about our Premier Line for large yachts, commercial vessels, military craft and fast fishing boats! Here's a couple of pictures:
redneck joe
I've had two boats with 20+ year old Bennetts with no issues and when I pur new on the Carver Mr Tabman was a great help in both choosing and installing. If you go Bennetts get the auto up accessory.
GMIslander
No Title
I installed Bennett Sport Tabs on my Trophy 1952 WA, they work great.
My previous boat was a Chaparral 196SSI, I installed smart tabs on that and they were a great addition as well.
Here is a before and after of the trophy, before left after right.
