- Mar 8, 2009
- 44,322
The 811544 looks correct except the high pressure hose is on the wrong side. I assume that both have the same drive rotation for the vanes?
AutoZone has 63131 in stock and I went to look at it. If not for the high pressure connection on the other side they look the same. Any suggestions
Wish I did but just cannot say. Mine was a saganaw and was able to pick up just the pump as your trying to do. The pump came right out of the housing and new one went in. I would guess it would work because Merc doesn't make the things and the pump other then the relief valve should be the same at the most. If you have the time take your off and take it in with you.
