- May 16, 2009
- 9,454
It' appear the early years of the 8.1's had a few camshaft sprocket designs while the crankshaft shows only one sprocket part number/design for all years.
Having your serial number and GM block engine code might help but being an 05, it should of been the newer design by then.
Some info of the new design for you.
http://www.bing.com/cr?h=c3i2yODrTJ...3E93E25BD5262A7049E38EABC5B6362&p=SERP,5140.1
Not sure if you've tried this or not yet, but since the tachometer is showing 3000 rpm at crank, you might want to disconnect the gray wire at the tachometer and see if it will start. A bad gauge will keep an engine from starting. Also it's a good idea to separate the boat wiring harness to the engine wiring harness and jump the engine harness to see if it will start.
