[FONT="]Greetings all, I am new and have just joined this forum!
I have a 1995 Mercury 175HP Outboard that is in alarm. When I turn the key to the on position the alarm initially sound 3 times then stops. (I have left it on for over 1 minute and it does not sound) After starting the motor the alarm continues to sound.[/FONT]
[FONT="]I have changed the water pump with a complete kit and put in new thermostats. Still alarms! (Note: telltale was sporadic when idling with flush muffs attached.)[/FONT]
[FONT="]I checked the float on the oil tank. Used ohm meter and read correctly when float was lowered.[/FONT]
[FONT="]I drained the fuel separator (which did have water in it) and replaced it with new filter. Still alarms![/FONT]
[FONT="]I am running out of things to try… Any thoughts or ideas?[/FONT]
[FONT="] [/FONT]
[FONT="]Thanks![/FONT]
[FONT="] [/FONT]
