minuteman62-64
- Apr 12, 2011
- 1,350
Haven't had a crimp connection fail yet, but, still not sure of correct way to use tool. My tool is one of those ratcheting types with two "jaws" for each wire size.
The "jaws" on the side where the color coding dots are located look like they are designed to squeeze a round or semi-round shape. The "jaws" on the other side look like they are designed to squeeze almost a flat shape.
It looks like the "jaws" on the color coded side are designed to squeeze the insulation of the connector to the insulation of the wire and the other jaws are designed to actually crimp the connector onto the stripped section of wire. So, I would insert the connector in the tool so the stripped wire would be inserted from the side with the color coding dots. That's the way it seems to work best.
Do I have it right?
Do I have it right?
