Mercruiser alpha one 350 wiring help
driver_dav
So i have seen you guys help someone on this type of issue and I am hoping I can get the same response.
Reinstalling my 350 with a thunderbolt IV in a Mercruiser alpha one gen 2, in a 1996 Maxum 2100SR and I have some wires hanging and I am some issues with them and the online diagrams I have found. Previous owner had it rebuilt and I believe some wires were hanging when i disassembled. Attached are the pictures of the wires, the two tan ones I am pretty sure go to the thermostat housing I just dont know which side they go on, the purple one with the flat blade style connector i am pretty sure was not connecting when i started to disassemble. the butt connector from the shift cutoff switch i figure went to the other butt connector but it would be tugging and over the upper intake
thanks in advance
alldodge
thanks in advance
Pics didn't make the trip
You sure that it is a TB-4. how many wires you have on the distributer?
Tan wires go to water temperature sender gauge. Now if one of them is a Tan/Blue it will go to the water temp switch. Both will be on the thermostat housing
Purple wires are 12V switched (are energized when key is turned to on). Having a flat blade connector I would suspect it would go to the electric choke
driver_dav
No Title
every time i try to post pictures i get this pop up, listed below
driver_dav
Edit Conversation
There has been a database error, and the current page cannot be displayed. Site staff have been notified.
driver_dav
I also just found a spring under the motor, anyone knows where this go?
The purple and black wire makes sense to why it was not hooked up, i cant find an electric choke on the carb 20140817_190909 (1024x576).jpg
