redneck joe
- Mar 18, 2009
- 15,884
I knew I was going to need new springs based on looking at the port side a couple months ago but due to an unrelated event (all lug nuts half off one wheel one hour into a two hour trip - somebody doesn't like me) I was checking all the wheels and looked at the other side leaf. The front side attaches to the hanger (complete loop) and the rear is in the shape of a 'C' i guess to allow some stress relief at the other hanger. Well it is about to fall out.
crappy pic, I'm going to the boat at lunch time to get better pics.
I had a lost wheel event a couple months ago http://forums.iboats.com/forum/other...he-water-until and pretty much had decided to rework everything below the frame this winter but moving that event up. Been trying to learn about this stuff for a few weeks.
the plan:
iboats doesn't do axles and it is not a 'standard' trailer at least with the Dexter axles from etrailer with pre-welded on spring seats and axleless systems are way to pricey so looks like trailerdepot or southwestwheel. Sorry so many questions but want to do it right.
here is the equalizer
and to my spring seat question mine look like this and do not see a seat? How do the seats work?
the plan:
- two new axles (3500 lbs - boat is 4000 dry weight)
- electric brakes on one
- new hubs
- new leaf springs
- new tires/wheels (current 3 year old ones are 14" and not happy with the flex on them)
- new LED lights (why not?)
- any thoughts on those two suppliers?
- spring seats - when I get them 'loose' do they need to be welded on or is it just a clamp on application?
- brakes - does it matter front/rear axle?
- currently my equalizer does not employ shackle straps - is that an issue? Assuming the 'C' shaped leaf allows the flex the straps would?
- I do not want to have to move any of the existing hangers do the shackle straps allow for a bit of variance in length of the springs?
- spindles with the zerk - replaces bearing buddy so just get dust cap?
- dexter talks about having a bend in the axle for camber - at my boat weight to axle rating should I need that?
- round or square tube matter?
- anything I need to know that i'm not thinking of?
- how long a job should I plan for?
- can it be done with boat on fairly easily?
- what pics would help you help me?
