Power steering line
vipertblck
Anybody got an idea where to get a power steering line for my '01 chaparral 180 sse? it's the pressure line that comes off the pump and to the "rack". p/n on line says 9030-06, but that may be a p/n from good year.
Bt Doctur
does it screw in to the steering unit or quick dis-connect,engine serial number would be helpful
vipertblck
it's the screw in style on both ends. leaking from pump housing on engine. I loosened and retightened, no luck. took out of pump housing and replaced o-ring on end of line, still no luck. When it's tight and I pull up slightly on line, it leaks even more. I'm assuming it's the line or the line is cracked. Engine serial is M041527
Bt Doctur
2 listed ,one has 2 90 deg fittings 806684 ,the other has 1 90 and 1 20 deg fitting 842435-45
