1979 Johnson 115 re installing flywheel.
TampaBoater
So in light of my motor's electrical problem i posted before (not firing on one bank), i have decided i will remove flywheel to inspect stator, and magnets. I have seen plenty of how to videos for removing the flywheel but barely anything on re-installing it. Is there a process for this? Can anyone shed some light on this? Thanks.
pn
just line up the woodruff key and crank on the nut to spec. strong impact gun should do it, don't use any lube. do not use any grease/oil
pn
don't use any pretroleum products, line up the woodrff key and impact the nut on.
TampaBoater
Sorry for my ignorance but i am not familiar with this woodruff key and crank you speak of. Could you clarify? Thanks.
markh28
Make sure you get the nut to torque specs for your particular motor. Under torqued flywheel nuts will shear the flywheel key.
TampaBoater
That's another thing. Where do i find such spec? I have a 79' johnson 115
markh28
Its in the factory service manual if you have one. There should be a torque specs section. I have a 1975 Evinrude 115HP and it is 100 FT LBS
