New prop. On the way.
trout74
Brianmc, You make sense in your interpretation of my situation. So are you saying I should go down in pitch? Or do you think I'm right where I should be? My boat was totally different today than any other day I've had it, which isn't long it's brand new this year. I also kinda think it came out of breakin mode today because it really gained a lot of speed and holeshot today. I was very impressed with the performance today. I wouldn't mind more if you have a suggestion but I am happy. I am in the lowest setting for the motor mount. How does a jack plate work and will it allow me to mount it lower? Thanks Trout
The Rooster
Ensign
Sounds like great news Graham. For what it's worth, I'm only able to trim up about a 1/4 while at speed before beginning to cavitate / ventilate as well. As I recall, it was the same on our Bentley w/ 200 Optimax.
BrianMc
When you guys say 1/4 trim are you talking from the full down position,or 1/4 up from neutral (center) trim? I can run 3/4 trim all day and never touch it. The last 1/4 I grab at speed. If I could only run at 1/4 trim (from bottom) I'd loose 4-5 mph off top end.
trout74
When I say 1/4 trim, my trim gauge has 5 hash marks. from full down position I trim up to the first hash mark ( 1/4 ) the whole trim available. If I was at 3/4 trim my entire lower unit is out of the water, and 100% trim its all the way up.
short answer, yes from full down, 1/4 up!
Hey how does a JP work, and whats a good brand to look at if it is useful for a Tritoon.
Thanks ,
Trout
The Rooster
Ensign
Thanks ,Trout
Same for me, Brian !!!
BrianMc
A jackplate will let you adjust the height of your motor. Most around 5" of vertical travel. There are many different varieties of JP's. Different setbacks (distance they set the motor back off the transom),different versions of slides,and whether they are manual or hydraulic. The main use for them are for go fast boats that are trying to run their motors as high as possible for less drag,while maintaining prop bite and water pressure to cool there motor. But as I suspected when I built mine on a tritoon we can use them to drop the motor for more trim. Not only that,it will also gain leverage to lift the bow same as a longer pry bar would. I didn't realize that normal was only 1/4 trim. I just knew looking at mine there was no way I could trim it out. I've been running them on different hulls for 20 yrs.
I'm using a hydr. 6" CMC. I'd stay with 6" or less of setback to keep stress to a minimum on the transom. I don't think there's any reason to even try a manual on a pontoon,as when I'm loading or running shallow I raise it to the top. Once away from the dock I bottom it out and leave it there. I mounted mine so the center of adjustment was near the same height as the motor was hanging on the transom. This gave me around 3" of drop,and 2" higher when loading on the trailer.
Now before you hold me to numbers,let me try mine out at only 1/4 trim and center on the plate. Haven't even tried that because it'll launch at 3/4 trim with the plate down. I just know between 3/4 and full trim I'm still gaining speed. We'd have to also see what transom angle your running compared to mine. Side view photos at 1/4 and full trim would help there.
BrianMc
Sounds to me like a 25" lower unit motor on a JP would be ideal for those toons. Just guessing here,but I bet I could still reach over 1/2 trim at normal mounting height. Wonder how tall your transoms are compared to mine?
Something you might want to checkout 1st is if your manufacturer will warranty your boat with a JP mounted on it.
craigmack
Trout, glad to hear your setup is working. Your numbers are the same as mine.
