Retrofiting Raw water cooled to closed cooling
tank1949
Is there anything after market that I can buy to retro my 5.7 s with closed cooling so that future "consumables" to replace or inspect would only be risers/elbows? The exhaust manifolds would pass antifreeze as well as engine block and heat exchangers. The only retro-fit I have been able to find so far would pass raw sea water through manifolds AND risers/elbows. Block and heat exchangers would only contain antifreeze coolant. Perhaps there is a reason why manifolds MUST have sea water passed through them as well. Perhaps too hot???????
I have owned 4 MC I/Os cooled with raw sea water and religiously flushed with fresh water after trips in salt water. Risers/elbows are the first to clog or restrict water flow. They are easy to inspect by "touch." If one side is hotter than the other, it usually means a passage is clogged or beginning to clog and you should remove and INSPECT and clear passages, if you can. They can be a pain in the butt to clean or unclog. I have never replaced an exhaust manifold due to leakage. I suspect risers fail as they are more exposed to hot gases and sea water.
Nonetheless, I am looking for a closed cooling system, where in the future, I would only have to inspect and replace risers/elbows. Any suggestions???
Bt Doctur
that would be called a full system and you would need the engine mounted pump and thru hull fitting
search "5.7 Blue Water inboard engines"
HT32BSX115
Absolutely,
I got mine for my 1997 Mercruiser 454 from http://www.oceaneastmarine.com/
There is one caveat though, if your engine has more than about 100hrs of salt water exposure, adding closed cooling can be problematic............ Mine had about 120 hrs of (only) fresh water exposure and was about 8 years old. I EXTENSIVELY flushed the block (removed core plugs) and manifolds to remove as much loose rust as possible before I installed mine. Loose rust can completely plug up the heat exchanger.
So far, I have 9 years of trouble free operation. I really like way it works and wouldn't operate without closed cooling now.
Many of the kits available for the 5.7L engine are "half" systems. You might contact the San Juan Engineering (Bellingham, Wa) tech support people and ask them what they have available and what their recommendations are.
https://www.facebook.com/pages/San-Juan-Engineering/158168510884003
Regards,
Rick
