mudsnowh2o
- Aug 8, 2011
- 17
Hey guys, I am a long time lurker and can usually find the answers I am looking for but this one has me a bit puzzled. I know I just need to pull the drive, I have the Merc #28 manual, and am very mechanically inclined, but I am just leaving that as the last resort since I have never had one off before. I guess I need to learn sometime, right?. I have been trying to track down a drive lube leak for a while now. The boat is a 2008, has a Bravo 3 and 350 mag, and has just over 80 hours. I bought it in the fall and upon closer inspection this spring, I could tell it had taken a hit because the skeg was about 1/2 the length it should be. That along with the fact that you can see scuff marks around the outdrive mounting nuts, tells me they have had the drive off before. I am pretty sure the lube is making it's way from the drive somewhere because the outside of the lube reservoir and the hose all the way into the transom is dry. Today I was lucky enough to catch a drip while in a contorted position with my head hanging down into the bilge, and it came from off of the starter.
I have seen quite a few posts that say people have removed the outdrive to find the U-Joint bellows full of lube, but wouldn't that lube have to come through the gimbal bearing, which would then run down where the drive shaft comes through the transom? I can find no lube anywhere near the drive shaft area. My question is what path would the lube take to get to the engine bell housing and the starter? Everything I can see from the top side of the transom is free of drive lube.
Note: I did have the dealer check the service records when I got the boat (the original owner bought the boat there and had his service done there) and it had only been in for routine maintenance besides a new impeller in 2012 so that could very well be when/why the drive was removed. I also forgot to mention the drive functions perfectly and there have never been any signs of water in the lube. Also it apparently leaks while sitting and not just while in use.
