1972 hydro electric 65 HP Johnson 65ESL-72S
I bought a project boat and the lower unit was missing from the above motor. I bought a second motor of the same model # and swapped the lower unit (low compression on the second motor). When swapping I installed a new impeller and Evinrude/Johnson "Electric Shift" lower unit oil .
In the driveway, connected to a hose and muffs, the motor shifts fine and has 11+ and zero volts as required to the wiring (grn/blue wires).
In the lake I only have FWD; no R or N.
In the lake, on the trailer, when I power the boat in Fwd. or Rev, I push the tow vehicle Fwd. No reverse at all.
Any ideas?- Thank You- TD
