Water temp.
rileyfam5
I have a 89 Bayliner Capri CC with a 2.3l ford i/o. I have a question. My temp gauge quit working. I found a leak and fixed it. Now the temp gauge works. I noticed that while the boat ran on the muffs in the yard, the temp got to around 210-230 and then went down. I noticed alot of steam coming from the stern where the exhaust bellows are at. Is this normal? Once the temp went down, i let it run for about 10min and it didnt move. It stayed around 140. Is this ok or do i have a problem?
I have a 89 Bayliner Capri CC with a 2.3l ford i/o. I have a question. My temp gauge quit working. I found a leak and fixed it. Now the temp gauge works. I noticed that while the boat ran on the muffs in the yard, the temp got to around 210-230 and then opened. I noticed alot of steam coming from the stern where the exhaust bellows are at. Is this normal?
Ayuh,..... The impeller is shot, 'n needs replacin' is my guess,....
jerryjerry05
Pull the cover off the drive and check the impeller.
How much pressure does the hose have?
The thermo is it in place?
