AeroCraft York 1960ish Transom, Stringers, Deck
saginawbayboater
Come on spring!!! :watermelon: 40 on the thermometer here today.
Hip number 2 monday 9am 3-9-15. The first one done last november couldn't be happier:rockon: Should be back at it in May or so.
Hope everyone is surviving the cold winter. I know i've had enough.
Mark72233
Ensign
Saginaw glad to hear the first one has worked out well. I hope the second one fairs as well. Be good to see you back on the boat again. Good lucks
saginawbayboater
Thanks Mark! I am on the mend now. Had a little snafu with the hip. I had surgery and was in the recovery room and they took a post op xray, and the techs jaw dropped. I was still pretty groggy, but i remember thinking "Houston we have a problem"! They told me I would be going back in for round 2. The hip had dislocated because the socket moved. Later I saw the xray and the ball was like not even close to the socket. Round 2 went much better he glued and screwed it we should be good to go. They say this is rare but it does happen! My Dr. and team at the hospital are awesome. This was hardest on them and I appreciate them being there for me. :thumb:
sphelps
Wow ! Good thing they caught it before they tried to send ya home !
Hope you have a speedy recovery/rehab !
Woodonglass
Hip, Hip, HOORAY!!!!:facepalm::crutch:
All kidding aside, Take Care and you'll be up and at em' in no time!!!:eek:nthego:
saginawbayboater
Thanks Wood! Slow going, one day at a time. The drive way is ice free and set up for hot laps with the walker!!! :lol:
Decker83
Great to hear your on the mend.. Take your time and get completely healed before trying to do to much.. The boat will wait for you..:D
I had a setback last July and still haven't got back at it full swing..:eek:
saginawbayboater
Thanks Decker and great to hear from ya! Hope your doing well!
saginawbayboater
Did a little stuff today sand, prime, sand, prime. That rusto primer has a lot of filler in it. I'm new to this so i'm trying to figure it out as I go.
sphelps
Glad to see your up and doing some stuff sbb !
Primer looks good !
saginawbayboater
Wow looking at the primer this morning it definitely needs more coats. Very spotty. Looks like a zebra.
Woodonglass
Really glad to see you're able to get up and at em'. :clap2:
Are you thinning the Primer? If so, don't thin it to much. You want to try and get to fairly heavy coats down.
saginawbayboater
Thanks wood! Feels awesome to be getting back on the boat. I did thin the rusto about 10% with the reducer. Sprayed a pint let it dry for an hour or so little sanded. And sprayed the second coat. I know the weather was completely bad 90 degrees super hi humidity, but I was going to spray some primer no matter what.
saginawbayboater
Need some help! I want to paint the motor Navy Blue and to get there with majic paint I will have to mix. So my question is this, do I buy ford blue and black as the two parts? Then play with mixture? Any input is appreciated! :fish2:
