Silvertip
- Sep 22, 2003
- 28,772
Re: Trailer Tire smoked and froze up
A cross-wrench looks like two steel rods crossed and welded in the middle. The end of each of three of these bars has a socket which fits a specific size lug nut. The forth end is flattened like a big screwdriver to pry off hub cabs. This is not what the manufacturers put in their cars but it's what you need if you tow a trailer as the lub nuts on the trailer are rarely the same size as your car or truck. <br /><br />As for how many jack stands you need -- technically you need only one if you work on one wheel at a time. Two if you want to support one axle or four if you want to support all four wheels of a tandem trailer.
