Do I have to drop the lower unit to adjust my shift rod?
Kettler
Dropped my lower unit for a water pump change and measured to the top of the shift rod not the center of the hole when installing my shift rod, got plenty of forward but no reverse !!! #$&)%!
Is there a way to screw the rod in a few turns without dropping the lower unit?
Thanks, Tight lines !!!
Kettler
Re: Do I have to drop the lower unit to adjust my shift rod?
boobie
What mtr is it ? The're some you can actually adjust from the top.
seahorse5
You can adjust the 60? motors shift rod without dropping the gearcase. If you have a 90? motor, get ready for some pulling and lifting.
kenmyfam
Just think, by the time you get the shift rod in the correct position you will be an absolute expert at lower unit removal and re-assembly :D
Good Luck and I hope you get it at the first attempt.;)
Kettler
Sorry been working TOO much my engine is a 1985 Evinrude 40HP
E40ELCOB
Don't know whats meant by 60 or 90 degrees?
Thanks
wilde1j
Doesn't apply to your motor ... only the V4 and V6's.
Kettler
So do I have to drop the lower unit then?
Thanks
samo_ott
Sorry been working TOO much. My engine is a 1985 Evinrude 40HP
E40ELCOB
Hey, I recently got that exact engine. Have not got it running well yet. Have both carbs off to rebuild and have the kits just have not done it yet. Let me know how it goes. I have not got to the LU yet so cant help you there.
Kettler
Thought so no big deal thanks much
Kettler
Hey Samo-ott....Awesome engine runs like a tank, yup drop the lower unit and put in a new water pump and see what else is going on down there.I did and was glad, other than the shift rod issue, replaced the water pump, exhaust gasket and drive shaft housing (which came as an assy. so dont buy the oil seals and save the shims) easy enough to work on and when in doubt its usually cheaper to buy a new part than $90/hr for a mechanic.
Check my threads too..drop me a line and if I can help I will
Nice rig bet she flies............
