Connecting the tach
Handyjim
There's a tach in the dash of our 1960s Glaspar, powered by an Evinrude 1960 75 HP. How do we connect the tach?
Lion hunter
Re: Connecting the tach
Need to know what kind of tach it is, original or aftermarket. And look at the back of the tach, is there a dial to set poles/pulses.
You may connect the tach to the distributor. Hopefully it is the correct tach. Do you have the battery power ign system or the magneto-powered ign system? Is the motor original to the boat?
Handyjim
Magneto system. I think the tach is an orig. Will check on Wednesday. So where on the distributor do I connect the tach?
I believe there is only one external connection on the distributor, on the "points" side of the coil. Try it.
Handyjim
I'll try it. Thanks for the tip.
