Randy Roark
- Jul 16, 2009
- 1
I have a 19 foot open bow larson boat and the tilt and trim motor will raise up but will not lower. The trim motor like makes a spinning noise does not even try too lower back down but will lift just fine, and I tried taking out the little screw on the side of the hydraulic bottle and it lowered but now when I tightened it back up it still leaks fliud from the screw I must have damaged the o ring or what ever is in the screw that when you tighten it, it seal the hole right? The real question is why don't the tilt and trim lower back down but will lift just fine. I did change the battery, and is it possible I messed up on hooking the right wires back to the right terminals on the battery? The boat worked fine last year I had it winterized and put up in a garage for the winter but somehow the key was left on and drained the battery so I replaced the battery and thats when I found the trim proplem. Please help me with my boat problem, I don't wanna have too buy another whole unit for this problem. Thank you
