transom replacement on aluminum boat
bipshoft
All,
I think I understand the importance of properly laminating and sealing my new transom
what I have not found out yet is if I need to put a sealant between my wood replacement transom and the actual aluminum hull
any suggestions?
thanks in advance
Woodonglass
Re: transom replacement on aluminum boat
Does the transom have knee braces? Does it have through bolts to bolt it to the outer skin?
bipshoft
has bolts to bolt it
it is actually on the outside and bolts up to the hull
Woodonglass
What does the inside look like
bipshoft
no wood at the bottom of the transom, just some angle bracing
there is a wood piece at the top (inside) that I will be replacing as well
looks like it just bolts onto the outer hull
I am still tearing into her so I might be able to get some pictures of the inside in a day or two
bipshoft
there are no knee braces that I can see so far
Woodonglass
Like to see a pic of the inside of the transom as well. I am not sure but I do NOT think that the original boat would have had wood on the outside of the boat for a transom. Maybe but not sure. How big of motor are you wanting to hang on her?
bipshoft
it currently has a 40hp rude on her
will get you more pictures in the next or so
Bob_VT
I think that huge piece of plywood is someones band aid repair :( That is NOT a standard aluminum design and defeats the aluminum hull.
Post a few photos of the whole boat and include the inside of the transom. Post a picture of the rating plate.
That boat looks very narrow?
bipshoft
Bob
thanks for the input
the boat is a 17 foot 59 Crestliner Flyingcrest
I will post pics as I get more torn out
looking at pictures at retrocrestliner, this seems to be the norm for that boat
they all seem to have externally mounted wood transoms
thanks again for the info and I will be getting more pics soon
Woodonglass
I did some research and it appears that you are correct. This boat has an exterior mounted wooden transom. Here is what I recommend. I would use 3/4 inch exterior grade plywood. Give it two coats of epoxy and then give it a layer of glass. Make sure and get the edges too! Do the same with the wood on the inside too. Get the pics of the inside as soon as you can.
bipshoft
Woodonglass
thanks for taking the time to research my project, Much appreciated
thats why I love this forum
still wondering if you would use any adhesive/sealer between the transom and the aluminum hull
any thoughts on that
thanks again all, much appreciated
Woodonglass
Yes, I would sand the aluminum and then apply some PL to adhere the wood to the transom.
bipshoft
woodonglass
thanks, that is the info I was looking for
I will upload some pics prior to doing this
Woodonglass
Hey bip,
I would also oversize my bolt holes and fille them with epoxy and then redrill them the correct size for the bolts. This way You will ensure that you will NOT get any water intrusion into the wood. Do everything you can to seal that wood PERMANENTLY!!! Pay close attention to the edges and to any holes you put into the transom. Screws should be pre-drilled and epoxy coated as well. You do NOT want to have to replace it again. Time spent now will give you more time on the water in the future.
I'm just sayin....;)
Bob_VT
I would NOT use PL to attach the wood to the transom. You could use 3m4200 which is non-permanent ........ if you ever need to repair you need to pry it away. If you use PL you will have to grind it away.
Since you have the old transom off....... you need to treat that aluminum before installation if the wood. Any and all bare spots should be wiped with vinegar, dried, sprayed with zinc chromate primer and any color paint.
The reason is regardless of how tight you "think" the seal is..... things will get between the layers. If the wood is sealed the aluminum is stall at risk for corrosion attack.
bipshoft
thanks for the great recommendations
hope to have the transom off this weekend (of course I need to sweet talk the wife into helping lift the motor off)
I will post pictures of it as I go
Woodonglass
Of Course the Supreme Mariner is correct. the 3M 4200 is a much better Choice and for all the right reasons. ;)
Bob_VT
Nope..... just guiding you through with experience and what I have seen happen here on iboats. When someone uses the wrong adhesive or encounters a boat where it was used in the wrong place....heartaches.
Wait until some posts that they can't separate a lower unit because they used 3m5200 when they did the water pump :eek: Yup have seen that here too.
