Short Version: The boat has become the worlds largest foot massager from 1000-3000 rpm either under way, or in not.
Long version: 7.4 454 B1 drive. After the third attempt to get a rebuilt engine purchased in 05 re rebuilt and finally done right, and finalize the perpetual re-powering of this boat, and countless thousands of dollars and hours later the engine is finally installed and the boat vibrates like nobodies business.
It does it in neutral, drive, reverse, turning left or right, going straight, and now I learned today after removing the outdrive it does it with no load as well.
It is really bad, and not that one would see from a bad gimbal bearing or u-joints while turning (still doing it with the drive removed eliminated them anyway) and it is literally driving me nuts.
Please offer your thoughts on this as everything I have come up with (as well as the mechanic involved) has not helped, and the changes proposed do not make any sense (eg. motor mounts etc) as they have little to do with being out of balance which is what causes vibes.
Except for the engine rebuilder missing something I am at a total loss here, and since it took a few months for the mechanic to actually swing this thing in I am really not looking forward to having to remove the engine again as it could cost the season.
I have been directed to the coupler, mounts, alignment, and others, but I cant see it being the mounts making it vibe, and the alignment should not come into play with the drive removed. I guess the coupler could be out of balance and be the cause, but it was fine previously, and even during initial break in before install there was not any obvious vibes.
Oddly after reaching planning speed the vibes reduced until barely noticeable, but upon throttling back the vibes increased violently to the worst levels.
I am running out of ideas, and cash as well so I wanted to reach out to you guys for help (ideas not cash lol) as I do not want to follow the path of changing out parts until we trip over the one causing the problem. Plus all of the proposed fixes not only include some pricey items, but also removing the engine once again, and I do not want to go through that just on a whim or guess.
So can a previously good coupler throw an engine out of balance? Would the builder be a good or better place to start just to be sure he did not leave anything out that could cause it? Is there anything I can check that I have missed?
Any help is welcome, and most appreciated!!
