BSDenning
Thread starter- Joined
- Nov 23, 2007
- 271
Hello everyone! I recently got pretty lucky and found a guy on craigslist that had several old outboard motors he was trying to get rid of. One of the motors he had was a 1957 Evinrude Fastwin 18hp. I've had my eye out for a motor like this because I've been wanting to give my jon boat a little more power. I gave the guy a call and offered him $50 for it. He agreed and then when I came to pick it up, he also gave me a 1956 Johnson 10hp. Unfortunately, the Johnson is locked up, but I took it anyway because you never know when you may need a part off of it. The guy said that the motors had been sitting in his barn for 20 or 30 years. They both definitely look their age. You can tell that they have been run in salt water by the corrosion on them. But, I figured I'd give it a shot and see if this 18hp is restorable. First, the recoil spring was broken on the starter. No problem, I just took the starter off the johnson and put it on the evinrude. The Johnson paid for itself already! Then I noticed that one of the fuel lines was cracked. I replaced it. I replaced the lower unit oil. It didn't seem to have any water in it. Dirt dobbers had made this motor their home over the years, so I spent some time with a screw driver scraping dirt out of the tale tale. I checked the coils and I didn't see any cracks in them. This motor even has the old Champion J6J plugs that you can't find anymore! I checked compression and it had 110 lbs. in each cylinder. Then, I decided to see if this old motor would crank. After pulling on it several times, it actually fired up and ran! I was really surprised that after all these years, it fired right up. It even pumped water and everything. So, I took it out to the river to see what it could do on my boat. It fired right up and ran great, but it stopped pumping water when I got it up to speed good, so I had to shut the motor down and troll back. Thoroughly convinced now that this motor is worth putting more money into, I have ordered a new impeller with ware plate and a carb rebuild kit. I should get them in the mail next week.
Now, on to my questions. I pulled the lower unit off to take a look at the impeller. When I pulled the lower unit off, the drive shaft actually came out of the powerhead AND the lower unit. It seemed to go right back in the lower unit with no problems, but I thought it was strange because I have changed the impeller in my 1957 Evinrude Fleetwin 7.5hp before and the drive shaft didn't come out of the lower unit when I did that. So, my first question is: Is it bad that the drive shaft came out of the lower unit?
When I got down to the impeller, it really didn't look in all that bad of shape. I was expecting it to be in pieces, but it was all in one piece. So, I put everything back together and took it down to the river again to see if it would pump water. The motor pumps water perfectly fine at idle and low speed, but when you increase the throttle and get up to speed, it quits pumping water. Then you bring it back down to idle and it starts pumping water again. Strange? I assume this problem will be fixed when I get my new impeller in the mail and replace it. Any thoughts on that? My guess is that it is so old that the little legs just bend over when it gets up to high speed and so it stops pumping water?
This poor little motor has been jery rigged to death! It has a Johnson tiller handle, a Johnson recoil starter (thanks to me), some type of strange round knob screwed in in the place of the choke knob (but it works), and instead of the water pump housing being attached by screws to the lower unit, someone has actually drilled through to the outside (where the bolts are that bolt on the lower unit to the exhaust housing assembly) and the waterpump housing is actually attached by bolts with nuts and lockwashers! I'm hoping that this is not the cause of my water pumping issues. I may have to include some pictures in this thread so you can see what I'm talking about.
I look forward to gaining more knowlege about this motor!
