Re: 1968 Johnson 65hp v4 - No Spark
No spark on all four cylinders using a spark tester.
New battery, new starter solenoid, rebuilt starter, and new plugs.
Next step?
Thanks,
Mike
Well, I could tell you to get a service manual, but it won't help you much because it will tell you to get a special neon tester which is no longer made.
How handy are you at troubleshooting electrical circuits? I can't give you the exact details, but the basics are:
1. See if you have 12V on the red wire going to the amplifier when the ign key is on. If not, find out why. If you do have 12V, go to 2:
2: Disconnect coil wire from amplifier, then unbolt coil and unscrew the whole thing from the distributor cap. Remount coil and connect amplifier wire. Rig up a spark gap off the end of the wire that you took out of the distributor cap. Crank engine: if you have spark off the coil wire the amplifier, breaker points, and coil are OK. No spark, go to 3:
3. Disconnect the wire going from the amplifier to distributor. Turn on key and brush the wire from the amplifier lightly across a bare metal item on the block. Does that create sparks off the coil wire? If yes, the amplifier and coil are good and you have a problem with the breaker points. (They are in the distributor).
4. If you have found that you have spark off the coil in #3, you have a problem with the distributor cap or rotor.
Distributor cap, rotor and breaker points are under the flywheel. You need a puller to get it off and a torque wrench to tighten the nut to 100 ft/lbs when reinstalling. All that stuff has to be clean, clean, clean. Breaker points gap is .009 at widest opening. There is an anti-reverse spring in there, a loop of silver wire. It must be in good condition and lubricated where it rides on the crankshaft with a VERY thin bead of EP grease.
We all had to go to school to learn this stuff. You just got the 5 minute course.
One last thing---a goof up in procedure can blow the expensive $$$$$ amplifier in a nano-second.
