I bought A 14 FOOT FISHING BOAT WITH A Johnson 9.9. The seller told me that the motor runs great,but has not been started in 2 years. He sprayed starter fluid in the carb. and it would fire right up ,for a couple of secs.Then die. I took it home and took the carb. apart and it had like jelly inside it. I cleaned it all up but it back together put new plugs,and it started right up !!!!took it to the lake and it would only run at a very slow speed. If i tried to turn the throttle it would die,and if i turned it down it would die. What does the knob that turns that says lean and rich on it/?? is that for idel or when it is in gear running?? Also the old owner told me to mix 20:1 that is what i did.
It looks like everyone wants you to mix 50:1
Does this motor have points ????
Thank for any help i can get.
