BanjoRed145
Thread starter- Joined
- Jan 24, 2010
- 11
I just picked up a 1960 Crestliner with a 35hp 1957 Johnson engine on it in unknown condition with a stuck throttle and shift lever. In my excitement to find out more about my new great find I decided to drain the lower unit to see what the fluid looked like. Having previously owned a 1962 Johnson 18hp I expected the drain to be on the side and not seeing the one on the bottom I accidentally pulled the pivot pin out.
Yes, I know, I'm an idiot. I even thought to myself "that's weird that they would use a phillips head on one plug and a flathead on the other." Now that I've screwed up I need to know how to fix it. My shop manual and several websites I have looked at since warn "do not pull out the pivot pin!" but they don't say what to do if you have.
Do I have to pull the whole lower unit off to fix this? Can I just pull off the bottom of the Skeg? Will all the gears fall out all over the place? Basically I am afraid of ripping everything apart and being in worse shape then I am now.
By the way......A little PB blaster on the shift lever and the throttle gears and both freed right up!!! Now I feel like I have a great project engine except for my idiocy. Any help offered would be great!
