lew-anderson
Thread starter- Joined
- Dec 13, 2009
- 3
I read the post at
http://forums.iboats.com/showthread.php?t=205628
and have a couple questions about the conversion. I'd be delighted anyone can help clarify the best approach to take.
Question 1:
In the post listed above the conversion was done on a 1958 Johnson 35 HP. The listed pump used was the sierra 18-7351 fuel pump. The box on that pump lists it as for the 9.9 and 15 hp motors but I see the barb on the discharge is the same size as is on the carb on my 1957 35 HP motor. The difference between the 18-7351 pump and the 18-7352 is just barb on the discharge - right? And since the carb has the smaller connector the pump with the matching connector (the 18-7351) will work just fine - right?
Question 2:
I got a single line connector for the fuel tank connection to the motor but the fuel hose that attaches to the barb on the back side of this connector and then runs to the fuel pump is larger than the two holes that were in the shroud for the 2 line system. What should I do for the fuel line between the connector and the pump? It also looks like the barb on the inlet of the pump is even larger than this larger line on the single line fuel connector - what's the deal there? Is there a different connector I should get that has a smaller barb on the back?
I'd hate to drill the shroud.
I've attached attached a photo of the connector.
Many thanks if anyone can point me in the right direction.
Question 1:
Question 2:
