Fletcher Arrow
madgadget
Re: Fletcher Arrow
The only way to bend plastic like that is to heat it. The screens are moulded in an oven. I know that the likes of Plancraft have ovens to do this. It may be worth a try?
I am not at all surprised about the stingers given the state of the rest of it :) I too am having to do my transom, but so far the rest appears solid. I hope that turns out to be the case too!
stoksey25
Re: Fletcher Arrow
I have been offered some very dense thick plastic sheet that looks the same thickness as the transom would this be any good to put in instead of marine ply thanks again Neil
ezmobee
Re: Fletcher Arrow
No. It would not have near the strength of plywood.
stoksey25
Re: Fletcher Arrow
ok thank you ply it is
regards Neil
Fisherball
Re: Fletcher Arrow
The floatation foam is there so if the boat swamps or capsizes it won't sink like a rock. It'll keep it at neutral bouyancy, kind of submerged but not sinking any deeper than the top of the water. Vastly increases survival chances.
stoksey25
Re: Fletcher Arrow
Hi , What sort of paint can be used on this sort of boat as I will need to paint it aswell . Does it have to be special paint or can automotive paint be used with plastic type primer? Regards Neil
stoksey25
Re: Fletcher Arrow
I am thinking ahead to engine fitting. What instruments would anybody recommend? The engine is a mariner 60 hp (believed to be 1985 but not sure). Do you need a speedo or can would a gps suffice any advise would be grateful
Regards Neil
ezmobee
Re: Fletcher Arrow
For paint, I highly recommend Petit Easypoxy for ease of application. I just painted my boat with it and it came out great.
For gauges, the most important is a tach. That will help you make sure your motor is propped correctly to be able to hit its target WOT RPM range. I wouldn't recommend a speedo. They are a pain to install and aren't terribly accurate. The ONLY reason I'm putting one back in my project boat is because it came with a functional tach and all the necessary holes in the transom are already drilled. I would not be putting one in otherwise.
stoksey25
Re: Fletcher Arrow
looked at the transom and am wondering how is the best way when I have the top off and old one out to secure the new one in after I have made it
stoksey25
Re: Fletcher Arrow
Hi there going to start replacing the stringers soon and wondered what wood is the best to use it looked like soft wood in there when it came out but im not sure
Regards Neil
ezmobee
Re: Fletcher Arrow
Marine ply would be the best. Properly sealed exterior ply second.
stoksey25
Re: Fletcher Arrow
Hi again . I have done my stringers today aswell as cutting my new floor which will be going in on moday ( I hope) the next part is the transom. I have looked at how the two halfs of the boat are fixed and after taking the rubber strip off found it is stapled together so got most of these out. When I have got the top off and old transom out how is the best way of fixing the new transom in? I was just going to resin and clamp the marine ply in then glass over the back. Would this be any good or would I be going aout it the wrong way. Many thanks again
Neil
stoksey25
Re: Fletcher Arrow
Hi got the floor in and fiberglassed in today also got the top off and took the rubbish transom out. Got to make the transom now before it goes in here are a few pics. I have not alot of room to do this in so I thought I would show you this also Regards Neil
stoksey25
Re: Fletcher Arrow on going
Hi again
I am looking into instruments now and need advise on what to get and how
I have a mariner 60hp 1986 with quicksilver controls . I am thinking I will need a speedo, tacho but how do i connect them is the multiplug that comes off the control box for this and can you get the plugs for it . What other instruments would I be able to fit like a temp and volt meter . Does anyone have any diagrams from the control box
Many thanks Neil
gandk
Re: Fletcher Arrow
hi there im in the uk too, and have a 1995 fletcher arrow sport 16 which im working on the new floor for it. Your looks a bit worse than mine though good luck with the transom. im hoping to keep mine in as it looks ok. There seems to be some good online fiberglass suppliers let me knwo how much you pay for it in the end.
stoksey25
Re: Fletcher Arrow
ok no worries
I would be interested in some photos of your boat to have a look where all seats , Instruments , fuel and the like go If you could I will send you my email address
King regards Neil
gandk
Re: Fletcher Arrow
sure no worries, theres a couple of pics in this thread i started about the deck
stoksey25
Re: Fletcher Arrow
Nice looking boat mate where are you in the uk
