78 Starcraft, V5-22, What do I have?
Status
Not open for further replies.
5speedhemi
Re: 78 Starcraft, V5-22, What do I have?
I bought it from the original owner and it says 1978 on the title... but it also says 250hp and it has 260hp in it... I do like that the listing on the 79 model you have pointed out did reference the Mariner 22V5 and the 1978 is only 21'
5 speed
Rickairmedic
5speedhemi You don't have a 78 I don't think, go to the link below it shows your model in the year 79 but not for 78 as well as a few newer.
http://www.iboats.com/Starcraft_Boats/bp/20br1466
Jim I dont think those records are 100 % correct either as you may note for both the 78 and 79 Mariner even the 79 22V5 shows it as an outboard powered boat and we all know at this point 5 speeds boat has a snarling Ford V8 in it :D.
Rick
5speedhemi
So is it a Super Sport 22 V5 ?
5 speed
JimbC
Well only you would know that I am only going by the model you posted which was 78 Starcraft, V5-22 and when you look it up that's the name that Starcraft has it as. Do you have a metal plate somewhere on the boat if so it will have the model and numbers of your boat.
5speedhemi
Yes the plate is mid ship next to the console. Badly faded and I didn't remember seeing anything legible. Could the hull Vin number shed any light?
STRD02701077F8
5 speed
BWR1953
5 speed
Take a good quality close-up photo of the plate and maybe we can photo-edit some info off of it by changing contrast, etc.
5speedhemi
You guy's just want me to uncover that beast and take lots of pictures!
STRD02701077F8
5 speed:D
Rickairmedic
We could be sneaky that way :D. A super sport would have had dual consloes from the factory . A mariner would have had a single center console from the factory if you do infact have a super sport you have what many of us consider the holy grail :D a 22' SS.
Rick
5speedhemi
Another piece of the puzzle!
1978 Super Sport 22 V-5
"This inboard/outboard runabout is 22.29 feet long and weighs 1400 (pounds dry). This weight does not account for passengers, fuel, or gear. The beam of this craft is 96 inches"
Well it describes the I/O and the 96" Beam...
5 speed :D
JimbC
5speedhemi, Here is the direct number to Starcraft / Smokercraft. Give them a call and that hull Vin and ask for the brochures and any questions you have about what model and year your boat is they will send that too you and tell you. Make sure you tell them that's the info you are looking for when you call then they will transfer you to the person that handles that. The 77 in the end tells me yours was a 77 year model. And Yes we would like to see more and better pics.:D
Starcraft Direct: 1-574-831-2103
5speedhemi
Thanks Jim! I called Starcraft and talked at length with Steve. He verrified that it is a 1978. He verrified that it has the deep V5 hull. He also verrified that no such boat exists! Starcraft did not make a I/O in the Islander for 78 or 79. He is going to get into the micro Fische and get me more info on what he thinks it is. He told me that is can't be a center console either! Steve said that it was a highly modified Holliday/Mariner/Islander! WoW!!!!!:D
5speed
JimbC
Well at least we are getting closer.:D It won't be long now we will know what it is that you have. UMMM! where the hell are those pics? We all are waiting.
I use http://picasa.google.com/ to host my pics others seem to like photo-bucket but I hate it cause of the stupid adds and it's slow. Download Picasa and up load your pics then we can see bigger better pics.:D
5speedhemi
Steve called me back and the micro fische are lost. He got with the "old timers" and they all came to the same conclusion that Starcraft has NEVER made a Mariner with an I/O engine! I guess I have a one of a kind. I'm ok with that. I will be trying to get in contact with the original owners that I bought the boat from to see what they have to offer as explaination. I called Grove Marine and they don't recall anything being done to the boat other than routine maintenance and of course the giving away of the Stringer outboard to a friend that needed it on their boat. Sun is out today so maybe I can get more pictures before the sun goes down !!!
5speed
JimbC
This was just what I suspected. I bet you have a Modified 1978 Super Sport 22 V-5. :eek:
5speedhemi
Yep!
5 speed
5speedhemi
Here's the Gross empty weight and max gross weight.
More clues to the mystery...
5 speed
5speedhemi
My bow with the teak steps and the rails.
5 speed
5speedhemi
Here's the raised area just behind the bow. It's raised up about 10"
5 speed
5speedhemi
Center console and seat.
5 speed
Status
