Painting Johnson O/B hood?
Terry Keeley
Tried a search but didn't get what I was after.
Have a '92 Johnson 6 with nasty hood, decals were shot, paint worn off in several areas. Found some great decals that are no longer available here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390042021351&ssPageName=STRK:MEWNX:IT
Got some OEM touch-up paint but wondering what primer to use on the composite hood, it's not fiberglass, looks to be a plastic of some sort.
Any ideas?
JBRacing
Re: Painting Johnson O/B hood?
I think Endura shot with a Badger touch-up gun will look fine! :)
ezmobee
I did this one with Rustoleum but my hood was fiberglass.
Terry Keeley
Yup, saw your post when I was searching earlier, nice work!
Called a tech this am, wasn't much help.:( He said they painted right on the plastic which I'm sure does well at the factory but I doubt would work for a touchup.
OEM touch-up paint says to look at service bulletin 2275, trying to get it from my dealer...
Terry Keeley
Decided to strip the old paint as it was worn off in areas and wouldn't have blended in well. Cowl seems to be some sort of plastic, anybody got any idea? ABS, PVC,? There's a few dings, what should I fill them with?
Dealer hasn't had any luck getting that bulletin yet...:mad:
kartman
their is a plastic panel adhesive called 747. the best for workin with plastics. and stronger than jb weld.
Terry Keeley
Thanks for the suggestions guys, I'll look into them.
Was at a plastics supply today for another project and brought the hood in, guy was quite sure it was ABS...
Bob_VT
Visit wally world or your local hardware store...... DUCO makes a 2 part plastic welder epoxy and it is really good stuff. I have rebuilt the spoon portion of fishing lures with it. Dries hard and can be sanded/painted...... since you are only filling dings I think it might work..... cheap too
Terry Keeley
Decided the dings were small enough to fill with some spot putty, shot a coat of primer first:
joza
I used Rustoleum white primer, orange and white paint and once done applied about 8 coats of crystal clear Rustoleum gloss coating.
The key is good prep up front, good primer and take your time.
Terry Keeley
Sanded with 400 grit dry, sanded well, didn't gum up at all, let it dry a coupla days tho...
Terry Keeley
Nice!
Terry Keeley
Came out pretty good for a rattle can job, hope this helps someone along the way...
KD Fisherman
That turned out better than new! Did you clear coat over the stickers to keep them from scratching?
Terry Keeley
Thanks! Nope, thought about clearing it but decided to just leave it...
JimbC
Terry that looks really good. You did a great job on that. I have a question has anyone ever found anywhere to get the rubber gasket that goes on an older outboard motor hood. I am looking for some.
