iammarcuse
- Oct 15, 2007
- 142
Hi, I posted previously about a surging problem on my 1990 2.6L 225 ETLD. http://forums.iboats.com/showthread.php?t=355556
It seems from the comments I was receiving I was tracking down a fuel restriction problem. I rebuilt the fuel pumps and saw no change in the symptoms. I did find this great thread on testing your fuel pumps. http://forums.iboats.com/showthread.php?t=283363 Mine seem to be plenty strong as they will draw a 6" Hg vacuum at idle with the fuel line clamped off.
After searching numerous posts I suspected the 'fuel feed assembly' which is a check valve between the filter and the lift pumps. Testing the fuel pressure at idle gave me almost 3" Hg with the valve in but barely 1" Hg without the valve. Is 3" too high at idle? Could it be causing a fuel restriction at higher rpms?
I will of course water test but I have to take it out of winter storage and so I want to make sure I am on the right track here before I do.
Thanks for any insight.
