How can I dissolve foam in the hull of my boat?
Solittle
Re: How can I dissolve foam in the hull of my boat?
You can cut, scrape, etc. to get the old stuff out but there is no solution that I know of that will disolve it. Gasoline and a match might do it rather quickly though.
Bob_VT
You can not. Whatever will disolve the foam will attack everything. It has to be chipped out by hand.
Moving to proper forum.
evildocrsx
have you tried using Gumout? I don't know if it will work or not as I have never tried it.
HVAC Cruiser
Don't know about desolving it, I used a sawzall to cut snapped out the big peices with a wonder bar and scraped. The remainder I got rid of with a flapper wheel
TojosMojo
yep you need to do it by hand by the scraping, chipping and cutting method...
coastalcruiser
if you have a dull blade on a electric chainsaw? that cuts it like butter!
86 century
Ensign
alot of stuff will do it. what is the hull made of
newbster
I never tried it but I hear a pressure washer will help cut through the foam.
