PROJECT ~ JEZABEL 23' Sleekcraft Executive ~ Turbo Restore ~ Tons of pics
vegasphotoman
Re: PROJECT ~ JEZABEL 23' Sleekcraft Executive ~ Turbo Restore ~ Tons of pics
thanks guys for the tips....
Im not too worried bout the trailer bend just yet, still tinkering with the trailer bearings and brakes, I want to now replace the hydraulic brake actuators, lots of rust up in em....
couple bearings spalled out so I need to replace cups and bearings, races etc
mrdjflores
well...you've convinced me...one of these SleekCraft Executives will be one of my next boats...
here's what i've found after looking for just a few minutes
vegasphotoman
OMG thats bad a%% call me old school but I like the plymouth superbird wing idea! lol awsome!
Hey MrDj if ya end up with one, they ride real nice! feel solid unlilke some of the little boats 18ft on down etc.....
I found that locally of all places, I can get a better deal on my bearings and seals! Vegas trailer supply..... $15 for 2 bearings,2 cups, cottern pin and wheel seal, Ill be returing the 3 other seals I bought and the one bearing I have left...back to NAPA...they were $11 ea part....thats lilke 3 times more expensive OUCH!
Im calling em today to see i f they got 3 kits in stock...
Raining here this week, so next week ought to be better for working ono the trailer
found rusty wheel brake actuators (inside under the rubber seal), still havent found the same hydraul actuators....really wanna replace those.....might hafta rebuild em instead...we will see!:D
vegasphotoman
PS Hey Mr Dj if you ended up getting that boat, if thats a real Superbird wing, you could probably ebay it for several hundred bux to recoup a few $$
vegasphotoman
Re: PROJECT ~ JEZABEL 23' Sleekcraft Executive ~ CHECKLIST
Well, heres the TO DO list...............I'll double post this on the 1rst posting of this thread maybye later...and check em off as completed!. Last update JAN 20th 2010
Must Do's or WANT to do's - GREEN indicates complete...Red needs to be done! before sea trials.............. Yellow is work in progress
-------BILGE / ENGINE
Clean and re-paint engine, polish chrome and exhaust COMPLETED
Replace all rubber hoses on engine COMPLETED
Compression test engine add marvel mystery oil to each cylinder before startup, replace spark plugs COMPLETED
Rebuild carb...adjust carb COMPLETED
Check ignition timing COMPLETED
BILGE - fix holes that we drilled to air out the pinhole leak in the frt of the bilge separator plate (frt of bilge) COMPLETED
BILGE - remove prev owner installed jerry rigged drain hole ...will post pic of that one! also found a screw blocking a hole, fixed that while in there (back of transom)COMPLETED
BILGE - add second NEW bilge pump <may not do that>
BILGE - replace old bilge pump hose it is swellled a bit... COMPLETED but with a snag!
BILGE Install new bilge exit port (3/4") prev owner had 3/4 inch hose clamped down onto 1/2" fitting! nice having bilge water come back ini the boat when it leaks eh? COMPLETED drilled bigger hole...replaced bilge exit port with 3/4" new fitting
BILGE - old bilge pump clean and test (it's the cartridge kind and is epoxied in) - COMPLETED / WORKS
BILGE - Gel coat entire bilge area! or paint it since we started doing that. COMPLETED (painted it aluminum)
BILGE - oil bilge blower and re-test or REPLACE bilge blower COMPLETED replaced with new atwood inline turbo
-----------STERNDRIVE
Sterndrive - Test trim/lift hydraulics - COMPLETE / WORKS but has leak!
Sterndrive - Found leak at port trim cylinder! need a reseal kit or replace BOTH cylinders I will check it off = once I look into it or fix it<>
Sterndrive - Order NEW upper housing, Starboard trim sensor, orings & gaskets & recieve parts - COMPLETED
Sterndrive - Replace upper housing, inspect guts, replace seals, re-assemble upper unit, mate to lower unit - current work in progress
Sterndrive - Strip and paint sterndrive and transom plate, gimbal Chrysler White!COMPLETED
-----------INTERIOR
Strip out old interior[/B] and chocolate colored carpeting BARF!! COMPLETED
Manufacture new captains seat base / cooler stowage COMPLETED
Cover new seat base with scrap vinyl from prev project, paint with tan vinyl paint COMPLETED
Engine box / jump seats Recover vinyl as needed, paint to match using vinyl paint COMPLETED
Engine box / jump seats Install into boat / bolt in place COMPLETED
go out and eat mexican food [/B]in celebration of interior work done YEA! COMPLETED
-----------TRAILER
Replace blown tire COMPLETED
Grease and inspect all wheel bearings <Work in progress>
Replace all wheel seals <Work in progress>
add bearing buddies <It had bearing buddies, Cleaned and re-installed em> COMPLETED
Check trailer brake pads -They were fine the wheel cylinders need replacing though!COMPLETED
Double check trailer lighting <>
---------COSMETICS
Poli-glow gelcoat restore the entire hull - COMPLETED looks awsome I-Boats should carry this product!
Make wood lattice for deck drop down area (I want a flat deck) COMPLETED came out awsome!
Polish trailer wheels COMPLETED We replaced the tires and rims Craigslist items YEA
Prep / Prime / Paint the whole trailer! <Got the paint the other day!>
Replace Bunk Carpeting <>
Repair a couple exterior gel coat chips and dings near transom <work in progress repaired all the dings and scrapes, holes....faired it all in ..have to sand the new gel coat down and polish it>
---------LEGAL STUFF
DMV title for trailer / out of state inspection of trailer / license plate <>
DOW boat title and tag <>
BOAT TAGS = Lake Mead Natl Rec area FEE AREA! need the OTHER tag for the boat <>
Make sure all safety equipment on board and TEST HER OUT on the water! <>
GETTING CLOSER to SPLASH!!!!!!!!!!!!!!
HVAC Cruiser
Hey Vegas, Great to see a new checklist up, looks like your getting closer to the bottom :D
You must be getting real itchy for that Last Item "TEST HER OUT"
Keep up the great work
vegasphotoman
O yeah I am ...so are quite a few other people...(the brother in laws, the wife, etc)
mrdjflores
if i get that boat, i may have to keep the wing on it :)
if i get a different one, i may have to add a wing to it :)
SKIBUM1M
Ok thats it you have convinced me. I love the look of the sleekcrafts. I guess that will be my next boat. I wonder if anyone will trade a half gelcoated and half sanded yellow larson with new floor and transom for one.
BobsGlasstream
How is it, people keep finding all these great boats. I can't find any. :(
Vegas,
Like the checklist. Looking forward to seeing that thing on the water.
Bob
archbuilder
Hey Vegas, I'm glad that your check list is getting short.....my paint prep list is longer than what you have left! :D Great boat, I can't wait to see it in the water!
sprintst
Yup. Not much left on the checklist. I don't want to do one as I might get depressed and need to go to Vegas or something :)
vegasphotoman
Thanks guys
yea they are cool boats, Bob Ill find ya one in your area!
ps I love the wing on that one sleek !!!!!!!! go plymouth!
I madea mod to my glastron before we sold it (used photoshop to do it)
83vert
THAT BOAT IS SICKKKKKKKKKKKKKKKK :eek::eek::eek::eek:
BobsGlasstream
Hey Vegas that would be really cool.
I think my wife would want to kill me for sure then. Pretty much normal. :D:D
I must be sick, Still have a ton to go on the one I'm working on and looking for another one. :eek:
We need more pic's of your progress.
Bob
Friscoboater
The boat with the wing is just COOL!!!!!!
archbuilder
Hmm wonder if it will fly? If so Bob will have one soon! We need pics Vegas....even if its just wheel bearings!
vegasphotoman
bump
BobsGlasstream
vegasphotoman,
Not Bump!! PIc's, pic's, pic's. :D
If it will fly, I'll give it a try. :p
Bob
